The following figure shows a sample IP Shortcuts over SPBM deployment.
Examples and network illustrations in this document may not include your specific platform. Unless otherwise noted, the concept illustrated applies to all supported platforms. For information about high-level feature support, see Fabric Engine and VOSS Feature Matrix.
The following sections show the steps required to configure the SPBM IP Shortcuts parameters in this example. You must first configure basic SPBM and IS-IS infrastructure. For more information, see SPBM and IS-IS Infrastructure Fundamentals.
Note the following:
SwitchC
CIRCUITLESS INTERFACE CONFIGURATION - GlobalRouter
interface loopback 1
ip address 1 10.0.0.1/255.255.255.255
exit
ISIS CONFIGURATION
router isis
ip-source-address 10.0.0.1
ISIS SPBM CONFIGURATION
spbm 1 ip enable
exit
VLAN CONFIGURATION
vlan create 13 type port-mstprstp 0
vlan members 13 1/2 portmember
interface Vlan 13
ip address 10.0.13.1 255.255.255.0
exit
IP REDISTRIBUTION CONFIGURATION - GlobalRouter
router isis
redistribute direct
redistribute direct metric 1
redistribute direct enable
exit
IP REDISTRIBUTE APPLY CONFIGURATIONS
isis apply redistribute direct
SwitchD
ip address 1 10.0.0.2/255.255.255.255
exit
ISIS CONFIGURATION
router isis
ip-source-address 10.0.0.2
spbm 1 ip enable
exit
VLAN CONFIGURATION
vlan create 14 type port-mstprstp 0
vlan member add 14 1/2
interface Vlan 14
ip address 10.0.14.1 255.255.255.0
exit
router isis
redistribute direct
exit
Verifying Operation — SwitchC
SwitchC:1# show isis spbm ip-unicast-fib
                         SPBM IP-UNICAST FIB ENTRY INFO
                                               OUTGOING   SPBM PREFIX  PREFIX   IP ROUTE
VRF   ISID    Destination    NH BEB    VLAN    INTERFACE  COST COST    TYPE     PREFERENCE  AREA  AREA-NAME
GRT    -      10.0.0.2/32    SwitchD     4000     1/30     20    1     Internal  7          HOME   area-9.00.02
GRT    -      10.0.14.1/24   SwitchD     4000     1/30     20    1     Internal  7          HOME   area-9.00.02
 Home : Total number of SPBM IP-UNICAST FIB entries 2
 Remote: Total number of SPBM IP-UNICAST FIB entries 0
SwitchC:1# show ip route
                            IP Route - GlobalRouter
                                                NH   INTER
DST         MASK           NEXT          VRF    COST  FACE	PROT AGE TYPE PRF
10.0.0.1   255.255.255.255  10.0.0.1      -       1     0 	 LOC	 0	  DB	 0
10.0.0.2   255.255.255.255  SwitchD      Glob~    20   4000  ISIS  0  IBS  7
10.0.13.1   255.255.255.0   10.0.13.1    -        1    13    LOC   0  DB   0
10.0.14.1   255.255.255.0   SwitchD      Glob~    20   4000  ISIS  0  IBS  7
4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed.
TYPE Legend:
I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout
e,
U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route
PROTOCOL Legend:
v=Inter-VRF route redistributed
Verifying operation — SwitchD
SwitchD:1# show isis spbm ip-unicast-fib
GRT     -       10.0.0.1/32    SwitchC     4000     1/20      20     1        Internal  7          HOME   area-9.00.02
GRT     -       10.0.13.1/24   SwitchC     4000     1/20      20     1        Internal  7          HOME   area-9.00.02
SwitchD:1# show ip route
                                                NH   INTER
10.0.0.1    255.255.255.255 SwitchC       Glob~  20   4000 ISIS 0   IBS  7
10.0.0.2    255.255.255.255 10.0.0.2      -      1    0    LOC  0   DB   0
10.0.13.1   255.255.255.0   SwitchC       Glob~  20   4000 ISIS 0   IBS  7
10.0.14.1   255.255.255.0   10.0.14.1     -      1    14   LOC  0   DB   0
TYPE Legend:
e,
PROTOCOL Legend:
